Ana içeriğe geç
Dell XPS 12 9Q23 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: adım 2, 1 resimden 1.
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Battery Replacement: adım 3, 1 resimden 1.
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: adım 5, 1 resimden 1.
    • Once all the screws have been removed the battery is now safe to extract
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Any tips for registering the new battery in the BIOS?
Ryan Porter - Yanıt
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 4,411
