Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Carefully remove back panel after all screws have been removed.
After the back panel has been removed, disconnect the battery to prevent electrical shock
Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
Once all the screws have been removed the battery is now safe to extract
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Any tips for registering the new battery in the BIOS?
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
