Ana içeriğe geç
Dell XPS 12 9Q23 Touch Pad Replacement
Neye ihtiyacın var
  1. Dell XPS 12 9Q23 Touch Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Touch Pad Replacement: adım 2, 1 resimden 1.
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Touch Pad Replacement: adım 3, 1 resimden 1.
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Touch Pad Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Touch Pad Replacement, Remove the battery: adım 5, 1 resimden 1.
    • Once all the screws have been removed the battery is now safe to extract
  6. Dell XPS 12 9Q23 Touch Pad Replacement, Touch Pad: adım 6, 1 resimden 1.
    • Unplug the trackpad cable.
  7. Dell XPS 12 9Q23 Touch Pad Replacement: adım 7, 1 resimden 1.
    • Insert wisdom here.
  8. Dell XPS 12 9Q23 Touch Pad Replacement: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 4 trackpad screws.
  9. Dell XPS 12 9Q23 Touch Pad Replacement: adım 9, 1 resimden 1.
    • Remove the trackpad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
DJ Jackson
384 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 1,620
