Ana içeriğe geç
Giriş
In this guide, we will be showing you how to remove and replace the Solid-State Drive.
Parçalar
Hiçbir parça belirtilmedi.
  1. Disconnect the battery cable from the system board.
    • Disconnect the battery cable from the system board.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Peel the tape that is adhered over the solid-state drive.
    • Peel the tape that is adhered over the solid-state drive.
  3. Remove the screw that secures the solid-state drive to the system board.
    • Remove the screw that secures the solid-state drive to the system board.
    • Slide and remove the solid-state drive out of the solid-state drive connector.
Sonuç
Johnathan Hammond
36.011 İtibar
408 adet Kılavuz yazıldı
Takım
Informative Technologies Inc. Informative Technologies Inc. üyesi
Community
15 Üyeler
930 adet Kılavuz yazıldı
Bir Yorum
Why remove the battery? You can disconnect it and it isn’t blocking access to the ssd.
Bart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 21
Her zaman: 393
