Giriş
This guide explains how to replace the motherboard in the Dell XPS 13 9350. The motherboard connects all the hardware components in the device and is a critical component. If your Dell XPS 15 is experiencing power issues a motherboard replacement might be necessary. To make sure this is the right fix, check the troubleshooting section for specific symptoms such as failure to boot, overheating and power issues.
Neye ihtiyacın var
Pull the battery cable connector towards the battery to disconnect it from its socket.
If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
Open the display and press the power button for five seconds to drain any remaining charge from the system.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to remove the little white connector by pulling it out and away from its socket.
Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
14 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
where is camera cable
Démontage pour changer la prise jack qui ne fonctionne plus et en plus provoque un bug empêchant les hauts parleurs de fonctionner. Au lieu du son normal j ai un crachotement . Je vais confier la micro soudure à un spécialiste
Je pense qu il vaut mieux ne pas forcer sur la carte mère pour sortir le ventilateur et attendre après l étape du démontage des vis de la cm pour le sortir
