Ana içeriğe geç
Dell XPS 13 9360 SSD Replacement
Neye ihtiyacın var
  1. Dell XPS 13 9360 SSD Replacement, SSD (Solid State Drive): adım 1, 1 resimden 1.
    • Power off your laptop and unplug it from the charger.
  2. Dell XPS 13 9360 SSD Replacement: adım 2, 2 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 2, 2 resimden 2.
    • Close the laptop lid and place it so the bottom side faces up.
  3. Dell XPS 13 9360 SSD Replacement: adım 3, 3 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 3, 3 resimden 2. Dell XPS 13 9360 SSD Replacement: adım 3, 3 resimden 3.
    • Use a Torx T5 screwdriver to remove eight 3 mm screws around the edge of the back cover.
  4. Dell XPS 13 9360 SSD Replacement: adım 4, 3 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 4, 3 resimden 2. Dell XPS 13 9360 SSD Replacement: adım 4, 3 resimden 3.
    • Lift the small magnetic flap cover in the center of the back case.
    • Use a JIS J0 screwdriver to remove the 6 mm screw under the flap cover.
  5. Dell XPS 13 9360 SSD Replacement: adım 5, 3 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 5, 3 resimden 2. Dell XPS 13 9360 SSD Replacement: adım 5, 3 resimden 3.
    • Wedge the guitar pick between the cover and the base of the laptop.
    • Start at the front edge of the base cover and continue around the perimeter of the laptop, carefully prying up the base cover.
    • Pull off the base cover.
    • As you use the guitar pick to work around the base cover, it will gradually loosen. You can then gently pull it off completely.
  6. Dell XPS 13 9360 SSD Replacement: adım 6, 3 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 6, 3 resimden 2. Dell XPS 13 9360 SSD Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery before removing the SSD.
    • Use the JIS J0 screwdriver to remove the single 2 mm screw securing the existing SSD.
    • The SSD will automatically "pop up".
    • Gently slide it out from the socket.
  7. Dell XPS 13 9360 SSD Replacement: adım 7, 2 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 7, 2 resimden 2.
    • Slide the new SSD into the slot at the same angle used when removing the old one.
    • Make sure to align the notches on the SSD correctly with the tab openings of the slot to avoid damaging the SSD and the PCIe slot.
    • Press down on the SSD gently to hold it down.
  8. Dell XPS 13 9360 SSD Replacement: adım 8, 3 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 8, 3 resimden 2. Dell XPS 13 9360 SSD Replacement: adım 8, 3 resimden 3.
    • Follow the remaining instructions in reverse order to reassemble.
    • Make sure that when you replace the back cover you press down along the edges to ensure that it snaps back into place.
  9. Dell XPS 13 9360 SSD Replacement: adım 9, 2 resimden 1. Dell XPS 13 9360 SSD Replacement: adım 9, 2 resimden 2.
    • Now you can power on the laptop again and use it!
Sonuç
Diana Ramirez-S.
269 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 57
