Ana içeriğe geç
Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement
Neye ihtiyacın var
  1. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 2, 1 resimden 1.
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 3, 1 resimden 1.
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 7, 1 resimden 1.
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Removing the Solid-State Drive: adım 8, 1 resimden 1.
    • Peel off the display cable tape from the hard-drive plate.
  9. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 9, 1 resimden 1.
    • Remove the two screws (M1.6x2.5) that secure the hard-drive plate to the system board with a Phillips 000 screwdriver head.
  10. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 10, 1 resimden 1.
    • Remove the hard-drive plate.
  11. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: adım 11, 1 resimden 1.
    • Gently slide and remove the solid-state drive from the solid-state drive slot (SSD not pictured in image).
    • Solid-state drives are fragile. Exercise care when handling the solid-state drive.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
44.953 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 6,018
