Ana içeriğe geç
Dell XPS 13 9365 2-in-1 Touchpad Replacement
Neye ihtiyacın var
  1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 2, 1 resimden 1.
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 3, 1 resimden 1.
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 7, 1 resimden 1.
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: adım 8, 3 resimden 1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: adım 8, 3 resimden 2. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: adım 8, 3 resimden 3.
    • Open the ZIF latch on the touch pad connector.
    • Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
  9. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 9, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two screws (M2x2) that secure the touch pad to the palm-rest assembly.
  10. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 10, 2 resimden 1. Dell XPS 13 9365 2-in-1 Touchpad Replacement: adım 10, 2 resimden 2.
    • Lift the touch pad from the inner edge and remove it from the palm-rest assembly.
Sonuç
Melissa Schlein
701 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 682
