Giriş
Use this guide to remove or replace your laptop's solid-state drive. The solid-state drive is the laptop's main file-storage device. This guide contains simple steps, but the SSD is fragile so be careful when removing or replacing it.
Neye ihtiyacın var
Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
Peel off the display cable tape from the hard-drive plate.
2 farklı kişi bu kılavuzu tamamladı.
