Ana içeriğe geç
Dell XPS 13 9370 Battery Replacement
Neye ihtiyacın var
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: adım 2, 1 resimden 1.
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: adım 3, 2 resimden 1. Dell XPS 13 9370 Battery Replacement, Remove the base cover: adım 3, 2 resimden 2.
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: adım 4, 1 resimden 1.
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: adım 5, 1 resimden 1.
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
Sonuç
To replace the battery & reassemble your device, follow these instructions in reverse order.
23 farklı kişi bu kılavuzu tamamladı.
Max Kletskov
40.298 İtibar
16 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.820 adet Kılavuz yazıldı
8 Yorum
Is the battery an original dell battery?
mnyousafva - Yanıt
Why doesn’t it say what tools are needed?
Noah Guirguis - Yanıt
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - Yanıt
Instructions were perfect, thanks for the great guide!
surfdaworld - Yanıt
Boom, in a good way! I fixed it!
Chris Cox - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 94
Son 30 gün: 527
Her zaman: 15,203
