Ana içeriğe geç
Dell XPS 13 L321X Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 13 L321X Battery Replacement, Battery: adım 1, 2 resimden 1. Dell XPS 13 L321X Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Battery Replacement: adım 2, 2 resimden 1. Dell XPS 13 L321X Battery Replacement: adım 2, 2 resimden 2.
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Battery Replacement: adım 3, 1 resimden 1.
    • Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
  4. Dell XPS 13 L321X Battery Replacement: adım 4, 2 resimden 1. Dell XPS 13 L321X Battery Replacement: adım 4, 2 resimden 2.
    • Take out 8 silver screws that are holding the battery with a PH00 head screwdriver.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
Ahmad EL Herbawi
499 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G3, Lacy Spring 2017 USF Tampa, Team S6-G3, Lacy Spring 2017 üyesi
USFT-LACY-S17S6G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 2,601
