Ana içeriğe geç
Dell XPS 13 L321X Mouse pad Replacement
Neye ihtiyacın var
  1. Dell XPS 13 L321X Mouse pad Replacement, Track Pad: adım 1, 2 resimden 1. Dell XPS 13 L321X Mouse pad Replacement, Track Pad: adım 1, 2 resimden 2.
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Mouse pad Replacement: adım 2, 2 resimden 1. Dell XPS 13 L321X Mouse pad Replacement: adım 2, 2 resimden 2.
    • Disconnect the ribbon cable with a plastic iFixit opening tool, by lifting up the black clip and by pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Mouse pad Replacement: adım 3, 1 resimden 1.
    • With a plastic iFixit opeing tool, insert it in between and remove the battery cable.
  4. Dell XPS 13 L321X Mouse pad Replacement: adım 4, 2 resimden 1. Dell XPS 13 L321X Mouse pad Replacement: adım 4, 2 resimden 2.
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
  5. Dell XPS 13 L321X Mouse pad Replacement: adım 5, 1 resimden 1.
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and by pulling the white ribbon.
    • Place aside.
  6. Dell XPS 13 L321X Mouse pad Replacement: adım 6, 3 resimden 1. Dell XPS 13 L321X Mouse pad Replacement: adım 6, 3 resimden 2. Dell XPS 13 L321X Mouse pad Replacement: adım 6, 3 resimden 3.
    • Remove four 2mm screws with a PH00 screwdriver.
    • Remove the mouse pad.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Ahmad EL Herbawi
499 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G3, Lacy Spring 2017 USF Tampa, Team S6-G3, Lacy Spring 2017 üyesi
USFT-LACY-S17S6G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 822
