Ana içeriğe geç
Dell XPS 15 Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Dell XPS 15 Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Dell XPS 15 Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 15 Motherboard Replacement: adım 2, 2 resimden 1. Dell XPS 15 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 15 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 15 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 15 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the bottom cover.
  6. Dell XPS 15 Motherboard Replacement, Battery Disconnection: adım 6, 2 resimden 1. Dell XPS 15 Motherboard Replacement, Battery Disconnection: adım 6, 2 resimden 2.
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 15 Motherboard Replacement, Fan: adım 7, 3 resimden 1. Dell XPS 15 Motherboard Replacement, Fan: adım 7, 3 resimden 2. Dell XPS 15 Motherboard Replacement, Fan: adım 7, 3 resimden 3.
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Dell XPS 15 Motherboard Replacement: adım 8, 2 resimden 1. Dell XPS 15 Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Dell XPS 15 Motherboard Replacement: adım 9, 2 resimden 1. Dell XPS 15 Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Dell XPS 15 Motherboard Replacement: adım 10, 2 resimden 1. Dell XPS 15 Motherboard Replacement: adım 10, 2 resimden 2.
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
  11. Dell XPS 15 Motherboard Replacement, Battery: adım 11, 2 resimden 1. Dell XPS 15 Motherboard Replacement, Battery: adım 11, 2 resimden 2.
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  12. Dell XPS 15 Motherboard Replacement: adım 12, 2 resimden 1. Dell XPS 15 Motherboard Replacement: adım 12, 2 resimden 2.
    • Do not pull up.
  13. Dell XPS 15 Motherboard Replacement: adım 13, 1 resimden 1.
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  14. Dell XPS 15 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the battery.
  15. Dell XPS 15 Motherboard Replacement, Motherboard: adım 15, 2 resimden 1. Dell XPS 15 Motherboard Replacement, Motherboard: adım 15, 2 resimden 2.
    • Remove the eight 4 mm Phillips #0 screws from the motherboard.
  16. Dell XPS 15 Motherboard Replacement: adım 16, 3 resimden 1. Dell XPS 15 Motherboard Replacement: adım 16, 3 resimden 2. Dell XPS 15 Motherboard Replacement: adım 16, 3 resimden 3.
    • Locate the red and black cable connector at the bottom right of the motherboard.
    • Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up.
  17. Dell XPS 15 Motherboard Replacement: adım 17, 3 resimden 1. Dell XPS 15 Motherboard Replacement: adım 17, 3 resimden 2. Dell XPS 15 Motherboard Replacement: adım 17, 3 resimden 3.
    • Use tweezers to flip open the Zero Insertion Force (ZIF) connector.
    • Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself.
  18. Dell XPS 15 Motherboard Replacement: adım 18, 3 resimden 1. Dell XPS 15 Motherboard Replacement: adım 18, 3 resimden 2. Dell XPS 15 Motherboard Replacement: adım 18, 3 resimden 3.
    • Use tweezers to flip open the white ZIF connector.
    • Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself.
  19. Dell XPS 15 Motherboard Replacement: adım 19, 3 resimden 1. Dell XPS 15 Motherboard Replacement: adım 19, 3 resimden 2. Dell XPS 15 Motherboard Replacement: adım 19, 3 resimden 3.
    • Use tweezers to flip open the ZIF connector.
    • Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself.
  20. Dell XPS 15 Motherboard Replacement: adım 20, 2 resimden 1. Dell XPS 15 Motherboard Replacement: adım 20, 2 resimden 2.
    • Use tweezers to detach the black cable connector out of its socket by pulling it to the right.
  21. Dell XPS 15 Motherboard Replacement: adım 21, 3 resimden 1. Dell XPS 15 Motherboard Replacement: adım 21, 3 resimden 2. Dell XPS 15 Motherboard Replacement: adım 21, 3 resimden 3.
    • Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right.
  22. Dell XPS 15 Motherboard Replacement: adım 22, 2 resimden 1. Dell XPS 15 Motherboard Replacement: adım 22, 2 resimden 2.
    • Locate the connector at the top right of the motherboard.
    • Use tweezers to detach the cable connector from its socket by pulling it to the right.
  23. Dell XPS 15 Motherboard Replacement: adım 23, 3 resimden 1. Dell XPS 15 Motherboard Replacement: adım 23, 3 resimden 2. Dell XPS 15 Motherboard Replacement: adım 23, 3 resimden 3.
    • Locate the last black cable connector.
    • Use tweezers to detach the black cable connector from its socket by pulling it to the right.
  24. Dell XPS 15 Motherboard Replacement: adım 24, 1 resimden 1.
    • Use your hands to lift up the motherboard.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Evan Shui
320 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S21G6
5 Üyeler
30 adet Kılavuz yazıldı
2 Yorum
where is camera cable
phong thanh - Yanıt
Wow man that is awesome job. Where can you get a newer motheboard for the same laptop?
R E - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 183
Her zaman: 23,725
