Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
With a huge display packed into a very sleek package, we didn't have high hopes heading into this assessment, but we were pleased to discover an overall lack of adhesive, standard screws, and publically-available repair documentation—all of which contributed to the XPS 13's 7 out of 10.
  1. Packaging and open reference shots. Packaging and open reference shots.
    • Packaging and open reference shots.
  2. Front and back reference shots. Front and back reference shots. Front and back reference shots.
    • Front and back reference shots.
  3. Removing the back cover is straightforward—remove the eight T6 screws and the single Phillips, then pry the back cover off. Removing the back cover is straightforward—remove the eight T6 screws and the single Phillips, then pry the back cover off. Removing the back cover is straightforward—remove the eight T6 screws and the single Phillips, then pry the back cover off.
    • Removing the back cover is straightforward—remove the eight T6 screws and the single Phillips, then pry the back cover off.
    iFixit mentioned that there are adhesive and tabs holding down the back cover.
    Does it have adhesive, or there are tabs?
    Because ideally, a laptop that is easy to repair shouldn’t have one-way tabs. (because how you can damage them when opening them up)
    Xavier Jiang - Yanıt
    I have this computer and a T6 doesn’t fit. I’ve seen other battery removal guides that say to use a T5.
    Ottilie Young - Yanıt
    True. It is a T5.
    Which is why I think I added the T5 screwdriver under the tools required.
    T6 is easy. You can find T6 bits for $1 on a street side shop. Even some power tools (craftsman) had it. T5 is much more rarer.
    For mine I replaced the T5 screws with my own T6 ones because T5 strips more often.
    And for the history, it has always been a T5. It’s a T5 on 2012 and 2016/7/8 so I don’t know why he got it mixed
    Xavier Jiang -
  4. Internal reference shot.
    • Internal reference shot.
    • Looks like battery, speakers, CMOS battery, SSD, wi-fi card, DC socket, and daughterboard are easily accessible.
  5. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Kit Satın Al
    Enough RAM
    For All The Tabs
    Kit Satın Al
  6. There's some tape over the battery so we peel it off before removing the four screws securing it to the lower case. There's some tape over the battery so we peel it off before removing the four screws securing it to the lower case. There's some tape over the battery so we peel it off before removing the four screws securing it to the lower case.
    • There's some tape over the battery so we peel it off before removing the four screws securing it to the lower case.
  7. Next out is the SSD and and the wireless card. All the cables we've encountered thus far have some tape on them. Not a ton, but some will need to be replaced unless you're very careful during disassembly. All the cables we've encountered thus far have some tape on them. Not a ton, but some will need to be replaced unless you're very careful during disassembly.
    • Next out is the SSD and and the wireless card.
    • All the cables we've encountered thus far have some tape on them. Not a ton, but some will need to be replaced unless you're very careful during disassembly.
    That’s a interesting notion. Back in my Dell XPS L321X there are few tapes. Wires run through the gaps between components.
  8. The display connector is a little tricky. It's secured by a bracket and five pieces of tape, but at least had a handy pull-tab to assuage worries about breaking the connector. The display connector is a little tricky. It's secured by a bracket and five pieces of tape, but at least had a handy pull-tab to assuage worries about breaking the connector. The display connector is a little tricky. It's secured by a bracket and five pieces of tape, but at least had a handy pull-tab to assuage worries about breaking the connector.
    • The display connector is a little tricky. It's secured by a bracket and five pieces of tape, but at least had a handy pull-tab to assuage worries about breaking the connector.
  9. We go to pull the fan out before the motherboard but its foot is caught in the way. So we remove six motherboard screws and the the thermal management comes right afterwards. So we remove six motherboard screws and the the thermal management comes right afterwards.
    • We go to pull the fan out before the motherboard but its foot is caught in the way.
    • So we remove six motherboard screws and the the thermal management comes right afterwards.
  10. Motherboard reference. Motherboard reference.
    • Motherboard reference.
    You did peel off the sticker. Great job.
    It had barcode of some apparently “important” things so I had not tore it down, but under the tape there’s some more numbers
  11. The trackpad comes out fairly easily—remove four screws and, unfortunately, a bit of tape. Then parts just start flying. After loosening a handful of Phillips screws we can remove the daughterboard (home to a USB port and SD card reader), speakers, RTC battery (which is just glued in place), and the DC-in socket. And after removing a couple dozen more screws, the keyboard comes out with no drama (and no tape!).
    • The trackpad comes out fairly easily—remove four screws and, unfortunately, a bit of tape.
    • Then parts just start flying. After loosening a handful of Phillips screws we can remove the daughterboard (home to a USB port and SD card reader), speakers, RTC battery (which is just glued in place), and the DC-in socket.
    • And after removing a couple dozen more screws, the keyboard comes out with no drama (and no tape!).
  12. The display assembly is held in with four Phillips screws and is easy to remove. Before discarding the palmrest, we pull out this small breakout board that drives the keyboard.
    • The display assembly is held in with four Phillips screws and is easy to remove.
    • Before discarding the palmrest, we pull out this small breakout board that drives the keyboard.
    • This particular board is very heavily glued in place, but it's unlikely you'll ever need to remove it.
    I think the screws to the display assembly can be accessed before removing the keyboard.
    The wires is another case, but since the WLAN card is pretty close to the hinge it shouldn’t be difficult.
  13. The Dell XPS 13 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair): Manufacturer provides free manuals online.
    • The Dell XPS 13 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • Manufacturer provides free manuals online.
    • Once you manage to take off the bottom cover, all the parts are pretty easily replaceable.
    • Screws and connectors are labeled, aiding reassembly.
    • Moderate adhesive—except for the display assembly, no heat is required to disassemble.
    • The layering could be improved to make certain components easier to remove, but overall the modular design makes repairs cheaper.
    • Soldered RAM means you'll never be able to upgrade when things get slow.
    I had the trouble with cracked plastic brackets, so I am pretty convinced that the “new” layout is better.
    The motherboard is made of silicon and had solder to "even” the compression force between the screw and the frame. The plastic crack because the topmost brackets are “squeezed” when you tighten the screw, so this time Dell put the fan “below” the motherboard.
    The battery fasteners are also different in the way that there is little “squeezing” force on the plastic tab as the screw mount is very slightly higher.
    Which means that all the parts will be fine even if it was overtightened for a bit. Now it’s only the configuration that decided how long it “lives” …
Bitiş Çizgisi
22 farklı kişi bu kılavuzu tamamladı.
Evan Noronha
194.918 İtibar
178 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
130 Üyeler
12.415 adet Kılavuz yazıldı
2 Yorum
What version of the XPS 13 9333 did you use for your demonstration? The one I have just looked at had a significantly different layout and assortment of connections. For example, the flat copper-colored U-shaped connector is flipped 180 from your image.
Actually, the images show a layout that is about 180 out from what I viewed.
tom
Tom W - Yanıt
I can confirm that the layout in 9343 / 9350 / 9360 is IDENTICAL. They shares the chassis.
The 9543 / 9550 /9560 and the precision shares the chassis (confirmed). Internals should be similar but varies wildly from configuration to configuration (e.g. a smaller battery and a 2.5 inch HDD OR a big battery with no 2.5 inch), discrete soldered or socket GPUs and the like.
The two looks very similar, so be rather sure. The 15 inch tend to get “better” stuff.
For the L321X, 9333, the 9q23 and the “older” models the layout IS different (but they should share the chassis)
Xavier Jiang -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 67
Son 30 gün: 351
Her zaman: 16,123
