Ana içeriğe geç
Dell XPS 13 Track Pad Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Dell XPS 13 Track Pad Replacement, Back Cover: adım 1, 2 resimden 1. Dell XPS 13 Track Pad Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Track Pad Replacement: adım 2, 2 resimden 1. Dell XPS 13 Track Pad Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Track Pad Replacement: adım 3, 1 resimden 1.
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Track Pad Replacement: adım 4, 1 resimden 1.
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Track Pad Replacement: adım 5, 1 resimden 1.
    • Remove the bottom cover.
  6. Dell XPS 13 Track Pad Replacement, Battery Disconnection: adım 6, 2 resimden 1. Dell XPS 13 Track Pad Replacement, Battery Disconnection: adım 6, 2 resimden 2.
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Track Pad Replacement, Battery: adım 7, 2 resimden 1. Dell XPS 13 Track Pad Replacement, Battery: adım 7, 2 resimden 2.
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  8. Dell XPS 13 Track Pad Replacement: adım 8, 2 resimden 1. Dell XPS 13 Track Pad Replacement: adım 8, 2 resimden 2.
    • Do not pull up.
  9. Dell XPS 13 Track Pad Replacement: adım 9, 1 resimden 1.
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Dell XPS 13 Track Pad Replacement: adım 10, 1 resimden 1.
    • Remove the battery.
  11. Dell XPS 13 Track Pad Replacement, Track Pad: adım 11, 2 resimden 1. Dell XPS 13 Track Pad Replacement, Track Pad: adım 11, 2 resimden 2.
    • Remove the four 3 mm Phillips #1 screws from the trackpad.
  12. Dell XPS 13 Track Pad Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to gently lift the upper-right corner of the track pad.
    • Remove the track pad by slowly pulling it up and away from you.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Arvind Krish
179 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S21G6
5 Üyeler
30 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 34
Son 30 gün: 152
Her zaman: 13,617
