Ana içeriğe geç
  1. Remove eight T5 Torx screws Remove a Philips screw under the plastic tab Remove a Philips screw under the plastic tab
    • Remove eight T5 Torx screws
    • Remove a Philips screw under the plastic tab
  2. Use opening picks to open the lower case Use opening picks to open the lower case
    • Use opening picks to open the lower case
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Disconnect the battery and move the battery cable out of the way Disconnect the battery and move the battery cable out of the way
    • Disconnect the battery and move the battery cable out of the way
  5. Remove a Philips screw Use a pair of tweezers to remove a metal clamp holding the wireless card Use a spudger to disconnect a couple of antenna cables
    • Use a pair of tweezers to remove a metal clamp holding the wireless card
    • Use a spudger to disconnect a couple of antenna cables
    • Pull the wireless card parallel to the motherboard
    • Do not lift the wireless card upward or risk damaging the wireless card slot
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
The Raptor
4.249 İtibar
7 adet Kılavuz yazıldı
3 Yorum
Removing it, all well and good, and don’t get me wrong, helpful. But what about installing the replacement, and especially what tools and how to reconnect the wireless card antenna cables.?
Steven Thibault - Yanıt
Taking the card is all well and good, and don’t get me wrong, this is helpful for that, but what about the other half, installing the replacement. Especially how to reconnect the wireless cards antenna cables and the tools necessary for that?
This article is incomplete. And it doesn’t address how easy it is to damage the wires connected to the wireless card.
Matthew Coburn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 Gün: 49
Son 30 Gün: 226
Her zaman: 7,526
