Ana içeriğe geç
Dell XPS 1340 CPU Fan Replacement
Neye ihtiyacın var
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: adım 1, 1 resimden 1.
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: adım 2, 1 resimden 1.
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: adım 3, 1 resimden 1.
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: adım 4, 2 resimden 1. Dell XPS 1340 CPU Fan Replacement: adım 4, 2 resimden 2.
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: adım 5, 2 resimden 1. Dell XPS 1340 CPU Fan Replacement: adım 5, 2 resimden 2.
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: adım 6, 1 resimden 1.
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Paras Tolani
188 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 2,806
