Ana içeriğe geç
Dell XPS 14 L401X Hard Drive Replacement
Neye ihtiyacın var
  1. Dell XPS 14 L401X Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Dell XPS 14 L401X Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Hard Drive Replacement, RAM: adım 2, 3 resimden 1. Dell XPS 14 L401X Hard Drive Replacement, RAM: adım 2, 3 resimden 2. Dell XPS 14 L401X Hard Drive Replacement, RAM: adım 2, 3 resimden 3.
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Hard Drive Replacement: adım 3, 2 resimden 1. Dell XPS 14 L401X Hard Drive Replacement: adım 3, 2 resimden 2.
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Dell XPS 14 L401X Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
  5. Dell XPS 14 L401X Hard Drive Replacement: adım 5, 2 resimden 1. Dell XPS 14 L401X Hard Drive Replacement: adım 5, 2 resimden 2.
    • Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
  6. Dell XPS 14 L401X Hard Drive Replacement: adım 6, 3 resimden 1. Dell XPS 14 L401X Hard Drive Replacement: adım 6, 3 resimden 2. Dell XPS 14 L401X Hard Drive Replacement: adım 6, 3 resimden 3.
    • Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
    • Detach the plastic cosmetic cover from the hard drive.
    • This cosmetic cover will be transferred to the new hard drive.
Sonuç
Nicole Johnson
428 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G3
3 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,294
