Ana içeriğe geç
Dell XPS 14Z L412Z Fan Replacement
Neye ihtiyacın var
  1. Dell XPS 14Z L412Z  Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z  Fan Replacement: adım 2, 2 resimden 1. Dell XPS 14Z L412Z  Fan Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z  Fan Replacement, Cooling Fan: adım 3, 2 resimden 1. Dell XPS 14Z L412Z  Fan Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • The fan is located on the upper right hand side of the laptop.
    • Unscrew the four 4.5mm Phillips #0 screws along the fan.
  4. Dell XPS 14Z L412Z  Fan Replacement: adım 4, 2 resimden 1. Dell XPS 14Z L412Z  Fan Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the fan connection by using the metal tweezers.
    • Then, plug in the new or cleaned fan back into the connection.
Sonuç
Cole Hanson
141 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team S8-G3, Ogden Spring 2018 UW Stout, Team S8-G3, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 722
