Ana içeriğe geç
Dell XPS 14Z L412Z Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 14Z L412Z Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Battery Replacement: adım 2, 2 resimden 1. Dell XPS 14Z L412Z Battery Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Battery Replacement, Battery: adım 3, 1 resimden 1.
    • The battery is on the bottom left side.
  4. Dell XPS 14Z L412Z Battery Replacement: adım 4, 1 resimden 1.
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Dell XPS 14Z L412Z Battery Replacement: adım 5, 2 resimden 1. Dell XPS 14Z L412Z Battery Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Colton Niewolny
411 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G3, Ogden Spring 2018 UW Stout, Team S8-G3, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G3
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 2,947
