Ana içeriğe geç
Dell XPS 14Z L412Z LCD Screen Glass Replacement
Neye ihtiyacın var
  1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: adım 1, 2 resimden 1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: adım 1, 2 resimden 2.
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Dell XPS 14Z L412Z LCD Screen Glass Replacement: adım 2, 2 resimden 1. Dell XPS 14Z L412Z LCD Screen Glass Replacement: adım 2, 2 resimden 2.
    • Using a heat gun, carefully apply heat evenly across the glass.
  3. Dell XPS 14Z L412Z LCD Screen Glass Replacement: adım 3, 2 resimden 1. Dell XPS 14Z L412Z LCD Screen Glass Replacement: adım 3, 2 resimden 2.
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
Sonuç
Colton Niewolny
411 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G3, Ogden Spring 2018 UW Stout, Team S8-G3, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G3
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 2,152
