Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using the iFixit opening tools, carefully pry up the trim around the screen.
Using a heat gun, carefully apply heat evenly across the glass.
Using the iFixit opening tools, carefully pry the glass off the screen.
Bir Yorum
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
