Ana içeriğe geç
Dell XPS 15 9500 Fan Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9500 Fan Replacement, Base Panel: adım 1, 1 resimden 1.
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Fan Replacement: adım 2, 2 resimden 1. Dell XPS 15 9500 Fan Replacement: adım 2, 2 resimden 2.
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Fan Replacement, Fan: adım 3, 2 resimden 1. Dell XPS 15 9500 Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws screws from each fan (four screws total).
  4. Dell XPS 15 9500 Fan Replacement: adım 4, 1 resimden 1.
    • Use an opening tool to push the left fan cable plug out of its socket.
    • Repeat for right fan cable.
  5. Dell XPS 15 9500 Fan Replacement: adım 5, 1 resimden 1.
    • Lift the fan up and away from the heatsink.
    • Repeat for the right fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bryan Chung
437 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team A-1, Bator Winter 2022 UC Santa Barbara, Team A-1, Bator Winter 2022 üyesi
UCSB-BATOR-W22SAG1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 62
Her zaman: 1,477
