Ana içeriğe geç
Dell XPS 15 9500 SSD Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: adım 1, 1 resimden 1.
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: adım 2, 2 resimden 1. Dell XPS 15 9500 SSD Replacement: adım 2, 2 resimden 2.
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: adım 3, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: adım 4, 1 resimden 1.
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: adım 5, 2 resimden 1. Dell XPS 15 9500 SSD Replacement: adım 5, 2 resimden 2.
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
Sonuç
Bryan Chung
437 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team A-1, Bator Winter 2022 UC Santa Barbara, Team A-1, Bator Winter 2022 üyesi
UCSB-BATOR-W22SAG1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 104
Her zaman: 4,842
