Ana içeriğe geç
Dell XPS 15 9500 Speaker Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9500 Speaker Replacement, Base Panel: adım 1, 1 resimden 1.
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Speaker Replacement: adım 2, 2 resimden 1. Dell XPS 15 9500 Speaker Replacement: adım 2, 2 resimden 2.
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 3.0 mm screws (one on each speaker).
    • Use an opening tool to lift out the speaker.
  4. Dell XPS 15 9500 Speaker Replacement: adım 4, 2 resimden 1. Dell XPS 15 9500 Speaker Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to push the left speaker's cable out of its port until it is disconnected.
    • The speaker on the right side isn't connected to the motherboard, and is only connected to the left speaker by a wire at the bottom.
Sonuç
Bryan Chung
437 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team A-1, Bator Winter 2022 UC Santa Barbara, Team A-1, Bator Winter 2022 üyesi
UCSB-BATOR-W22SAG1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 32
Her zaman: 850
