Ana içeriğe geç
Dell XPS 15 9510 Hinges Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9510 Hinges Replacement, Lower Case: adım 1, 1 resimden 1.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Hinges Replacement: adım 2, 1 resimden 1.
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Hinges Replacement: adım 3, 1 resimden 1.
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Hinges Replacement, Battery: adım 4, 2 resimden 1. Dell XPS 15 9510 Hinges Replacement, Battery: adım 4, 2 resimden 2.
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  5. Dell XPS 15 9510 Hinges Replacement: adım 5, 1 resimden 1.
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Hinges Replacement: adım 6, 2 resimden 1. Dell XPS 15 9510 Hinges Replacement: adım 6, 2 resimden 2.
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
  7. Dell XPS 15 9510 Hinges Replacement, Display Assembly: adım 7, 1 resimden 1.
    • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
  8. Dell XPS 15 9510 Hinges Replacement: adım 8, 1 resimden 1.
    • Remove five screws that connect the display using a Phillips #00 screwdriver.
  9. Dell XPS 15 9510 Hinges Replacement: adım 9, 1 resimden 1.
    • Carefully remove the display from the Dell XPS 15 9510.
  10. Dell XPS 15 9510 Hinges Replacement, Hinges: adım 10, 2 resimden 1. Dell XPS 15 9510 Hinges Replacement, Hinges: adım 10, 2 resimden 2.
    • Heat the iOpener in the microwave for 30 seconds.
    • Place the iOpener on top of the laptop where the hinge is connected. Leave it there until the glue holding it in place melts.
  11. Dell XPS 15 9510 Hinges Replacement: adım 11, 3 resimden 1. Dell XPS 15 9510 Hinges Replacement: adım 11, 3 resimden 2. Dell XPS 15 9510 Hinges Replacement: adım 11, 3 resimden 3.
    • Pull out the hinges using a pair of needle nose pliers.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 85
