Giriş
Laptop hinge replacement is important because it ensures that the display system stays in place without wobbling, moving, or being too tight. A broken hinge will affect the usability of your laptop. This guide will show you how to replace the hinges using the iFixit iOpener tool.
Neye ihtiyacın var
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Using the small battery pull tab, disconnect the battery connector from the motherboard.
Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
Heat the iOpener in the microwave for 30 seconds.
Place the iOpener on top of the laptop where the hinge is connected. Leave it there until the glue holding it in place melts.
