Ana içeriğe geç
Dell XPS 15 9530 Base-Cover Assembly Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9530 Base-Cover Assembly Replacement, Unscrewing the Base-Cover Assembly: adım 1, 1 resimden 1.
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Dell XPS 15 9530 Base-Cover Assembly Replacement, Prying Off the Base-Cover Assembly: adım 2, 1 resimden 1.
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Sonuç
Bir başkası bu kılavuzu tamamladı.
William Daniels
824 İtibar
6 adet Kılavuz yazıldı
Bir Yorum
I need to replace these screws. What is the size, dimension, type?
Jason Benci - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 498
