Giriş
Removal of the battery will be covered in this guide. Be careful disconnecting cables as to not break them or their connectors.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
Bir başkası bu kılavuzu tamamladı.
