Ana içeriğe geç
Dell XPS 15 9530 Screen Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9530 Screen Replacement, Base Cover: adım 1, 3 resimden 1. Dell XPS 15 9530 Screen Replacement, Base Cover: adım 1, 3 resimden 2. Dell XPS 15 9530 Screen Replacement, Base Cover: adım 1, 3 resimden 3.
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Screen Replacement: adım 2, 2 resimden 1. Dell XPS 15 9530 Screen Replacement: adım 2, 2 resimden 2.
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Screen Replacement: adım 3, 1 resimden 1.
    • Lift the lower case off.
  4. Dell XPS 15 9530 Screen Replacement, Battery: adım 4, 2 resimden 1. Dell XPS 15 9530 Screen Replacement, Battery: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Screen Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Screen Replacement: adım 6, 1 resimden 1.
    • Lift the battery off the chassis.
  7. Dell XPS 15 9530 Screen Replacement, SSD: adım 7, 1 resimden 1.
    • Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
  8. Dell XPS 15 9530 Screen Replacement: adım 8, 2 resimden 1. Dell XPS 15 9530 Screen Replacement: adım 8, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
  9. Dell XPS 15 9530 Screen Replacement: adım 9, 1 resimden 1.
    • Pull the SSD out parallel to the mainboard.
  10. Dell XPS 15 9530 Screen Replacement, Screen: adım 10, 2 resimden 1. Dell XPS 15 9530 Screen Replacement, Screen: adım 10, 2 resimden 2.
    • Unplug the screen connector.
  11. Dell XPS 15 9530 Screen Replacement: adım 11, 2 resimden 1. Dell XPS 15 9530 Screen Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
  12. Dell XPS 15 9530 Screen Replacement: adım 12, 1 resimden 1.
    • Pull chassis away from screen assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 1,360
