Ana içeriğe geç
Dell XPS 15 9530 Touch Pad Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9530 Touch Pad Replacement, Battery: adım 1, 2 resimden 1. Dell XPS 15 9530 Touch Pad Replacement, Battery: adım 1, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  2. Dell XPS 15 9530 Touch Pad Replacement: adım 2, 1 resimden 1.
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  3. Dell XPS 15 9530 Touch Pad Replacement: adım 3, 1 resimden 1.
    • Lift the battery off the chassis.
  4. Dell XPS 15 9530 Touch Pad Replacement, Touch Pad: adım 4, 3 resimden 1. Dell XPS 15 9530 Touch Pad Replacement, Touch Pad: adım 4, 3 resimden 2. Dell XPS 15 9530 Touch Pad Replacement, Touch Pad: adım 4, 3 resimden 3.
    • Remove the touch pad ribbon cable by lifting the small plastic flap and pulling ribbon straight out of the connector.
  5. Dell XPS 15 9530 Touch Pad Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the four 3mm screws holding in the touchpad assembly.
  6. Dell XPS 15 9530 Touch Pad Replacement: adım 6, 3 resimden 1. Dell XPS 15 9530 Touch Pad Replacement: adım 6, 3 resimden 2. Dell XPS 15 9530 Touch Pad Replacement: adım 6, 3 resimden 3.
    • Lift the bottom of the touchpad and pull directly out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 5,768
