Giriş
Removal of the touch pad will be covered in this guide. To successfully remove the battery, a #0 Phillips screwdriver, a T5 Torx screwdriver, and a plastic spudger are needed. Be careful disconnecting cables as to not break them or their connectors.
Neye ihtiyacın var
Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
Remove the touch pad ribbon cable by lifting the small plastic flap and pulling ribbon straight out of the connector.
Bir başkası bu kılavuzu tamamladı.
