Giriş
If your Dell XPS 15 9550 laptop will not power on without being plugged in or not hold a charge for an extended period of time, you may need to replace your battery.
Aletler
Parçalar
Turn the laptop upside down.
Using a T5 Torx Screwdriver, remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Using a Philips #00 Screwdriver, remove the seven 3 mm long screws from the perimeter of the battery.
20 farklı kişi bu kılavuzu tamamladı.
2 Yorum
… Mais avec un prix imbattable, la batterie made in RPC arrive avec un connecteur très très épais !
Finalement il m’a fallu me résigner à forcer très durement l’intromission avec deux paires de pinces !!!
Barbare mais efficace ! C’est le contraire de out ce que j’ai enseigné pendant des années : “le connecteur approprié doit toujours s’insérer en douceur” Ben là … NON !
English translation:
… But with an unbeatable price, the battery made in RPC comes with a very very thick connector!
Finally, I had to resign myself to forcing the intromission very hard with two pairs of pliers !!!
Barbarian but effective! It’s the opposite of what I’ve taught for years: “the right connector should always fit smoothly” Well there… NO!
