Ana içeriğe geç
Dell XPS 15 9550 RAM Replacement
Neye ihtiyacın var
    1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: adım 1, 1 resimden 1.
      • Turn the laptop upside down.
      • Make sure the laptop is turned off.
      • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 15 9550 RAM Replacement: adım 2, 2 resimden 1. Dell XPS 15 9550 RAM Replacement: adım 2, 2 resimden 2.
      • Open up the information panel door (on the middle of the back side).
      • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 15 9550 RAM Replacement: adım 3, 3 resimden 1. Dell XPS 15 9550 RAM Replacement: adım 3, 3 resimden 2. Dell XPS 15 9550 RAM Replacement: adım 3, 3 resimden 3.
      • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
      • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS 15 9550 RAM Replacement, RAM: adım 4, 2 resimden 1. Dell XPS 15 9550 RAM Replacement, RAM: adım 4, 2 resimden 2.
      • There are 2 separate RAM sticks.
      • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
      • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 15 9550 RAM Replacement: adım 5, 2 resimden 1. Dell XPS 15 9550 RAM Replacement: adım 5, 2 resimden 2.
      • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
jbaseballin2
123 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team S6-G1, Ogden Fall 2018 UW Stout, Team S6-G1, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G1
4 Üyeler
26 adet Kılavuz yazıldı
1Rehber Yorum
What type ram do you replace it with? Could you post a link?
twrfan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 40
Her zaman: 9,719
