Ana içeriğe geç
Dell XPS 15 9560 Motherboard Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Motherboard Replacement: adım 3, 1 resimden 1.
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Motherboard Replacement, Battery: adım 4, 1 resimden 1.
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Motherboard Replacement: adım 5, 1 resimden 1.
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
  7. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: adım 7, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): adım 9, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  10. Dell XPS 15 9560 Motherboard Replacement: adım 10, 1 resimden 1.
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: adım 11, 1 resimden 1.
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  12. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: adım 12, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  13. Dell XPS 15 9560 Motherboard Replacement: adım 13, 1 resimden 1.
    • Disconnect the wireless card cables from the wireless card.
  14. Dell XPS 15 9560 Motherboard Replacement: adım 14, 1 resimden 1.
    • Slide the wireless card out of its slot.
  15. Dell XPS 15 9560 Motherboard Replacement, Fans: adım 15, 1 resimden 1.
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  16. Dell XPS 15 9560 Motherboard Replacement: adım 16, 1 resimden 1.
    • Unplug the fan cable.
  17. Dell XPS 15 9560 Motherboard Replacement: adım 17, 1 resimden 1.
    • Carefully remove the left-side fan.
  18. Dell XPS 15 9560 Motherboard Replacement: adım 18, 1 resimden 1.
  19. Dell XPS 15 9560 Motherboard Replacement: adım 19, 1 resimden 1.
    • Remove the right-side fan.
  20. Dell XPS 15 9560 Motherboard Replacement, RAM: adım 20, 2 resimden 1. Dell XPS 15 9560 Motherboard Replacement, RAM: adım 20, 2 resimden 2.
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  21. Dell XPS 15 9560 Motherboard Replacement, Motherboard: adım 21, 1 resimden 1.
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  22. Dell XPS 15 9560 Motherboard Replacement: adım 22, 1 resimden 1.
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  23. Dell XPS 15 9560 Motherboard Replacement: adım 23, 1 resimden 1.
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  24. Dell XPS 15 9560 Motherboard Replacement: adım 24, 1 resimden 1.
    • Remove the motherboard.
Sonuç
Jada Houser
790 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G5
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 95
Her zaman: 3,715
