Ana içeriğe geç
Dell XPS 15 9560 Solid State Drive (SSD) Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Back Panel: adım 1, 1 resimden 1.
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: adım 3, 1 resimden 1.
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): adım 4, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  5. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: adım 5, 1 resimden 1.
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  6. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: adım 6, 1 resimden 1.
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Frederick Rowell
175 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G5
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 54
Her zaman: 2,233
