Ana içeriğe geç
Dell XPS 15 9560 Wireless Card Replacement
Neye ihtiyacın var
    1. Dell XPS 15 9560 Wireless Card  Replacement, Back Panel: adım 1, 1 resimden 1.
      • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
      • Shut the laptop down.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 15 9560 Wireless Card  Replacement: adım 2, 1 resimden 1.
      • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 15 9560 Wireless Card  Replacement: adım 3, 1 resimden 1.
      • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
      FixBot'a Sor
      Yorum Ekle
    4. Dell XPS 15 9560 Wireless Card  Replacement: adım 4, 1 resimden 1.
      • Use a scribe to remove the bottom base cover from the backplate.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS 15 9560 Wireless Card  Replacement, Wireless Card: adım 5, 1 resimden 1.
      • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 15 9560 Wireless Card  Replacement: adım 6, 1 resimden 1.
      • Disconnect the wireless card cables from the wireless card.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 15 9560 Wireless Card  Replacement: adım 7, 1 resimden 1.
      • Slide the wireless card out of its slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jada Houser
884 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G5
4 Üyeler
33 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 2,801
