Giriş
If the display on your Dell XPS 15 9570 is damaged or will not turn on, you may consider replacing the display assembly. This do-it-yourself guide will walk you through each step of removing the display assembly from the rest of the display case.
The display assembly constitutes the front panel of the display portion of your Dell XPS. Other than the obvious signs of damage or malfunction, other symptoms may tell you it is time to replace the display. These include the appearance of “dead” pixels, splotches, or a screen that is having trouble reaching full brightness.
Before using this guide, you may check the settings on your device for brightness and contrast to see if the image cannot be corrected.
Check to make sure that you have all of the required tools and parts before beginning this guide. A steady hand and attention to detail is required to complete these tasks.
Be sure to power off the device before beginning work on any electronic application (see step one).
Neye ihtiyacın var
Remove the ten 3mm T5 Torx screws located on the outer perimeter of the device.
Use a Phillips #00 screwdriver to remove the two 10mm screws under the flip up plate.
Remove the rear panel using a plastic spudger. Its easiest to start from the top and work your way to the bottom.
8 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I have a 9570 with a 1080 non-touch screen. This page lists an amazon screen that is 4k with touch. Looking at the product page, it does not mention the 9570 but does mention the 9560. Will the 4k touch screen work? I would like to make this upgrade but am skeptical.
