Ana içeriğe geç
Dell XPS 15 9570 Display Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9570 Display Replacement, Display: adım 1, 3 resimden 1. Dell XPS 15 9570 Display Replacement, Display: adım 1, 3 resimden 2. Dell XPS 15 9570 Display Replacement, Display: adım 1, 3 resimden 3.
    • Power off your XPS 15 before beginning the disassembly.
    • Remove the ten 3mm T5 Torx screws located on the outer perimeter of the device.
    • Use a Phillips #00 screwdriver to remove the two 10mm screws under the flip up plate.
    • Remove the rear panel using a plastic spudger. Its easiest to start from the top and work your way to the bottom.
  2. Dell XPS 15 9570 Display Replacement: adım 2, 3 resimden 1. Dell XPS 15 9570 Display Replacement: adım 2, 3 resimden 2. Dell XPS 15 9570 Display Replacement: adım 2, 3 resimden 3.
    • Before proceeding, be sure to disconnect the battery. Failure to do so may cause damage to the device.
    • Using a plastic spudger, pull down on the connector towards the battery to disconnect it.
  3. Dell XPS 15 9570 Display Replacement: adım 3, 3 resimden 1. Dell XPS 15 9570 Display Replacement: adım 3, 3 resimden 2. Dell XPS 15 9570 Display Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two screws holding down the the display cable fastener.
    • This will reveal the display connector.
  4. Dell XPS 15 9570 Display Replacement: adım 4, 3 resimden 1. Dell XPS 15 9570 Display Replacement: adım 4, 3 resimden 2. Dell XPS 15 9570 Display Replacement: adım 4, 3 resimden 3.
    • Remove the yellow sticker holding down the connector.
    • Pull up on the black tab to disconnect the display connector from the motherboard.
  5. Dell XPS 15 9570 Display Replacement: adım 5, 3 resimden 1. Dell XPS 15 9570 Display Replacement: adım 5, 3 resimden 2. Dell XPS 15 9570 Display Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the screw from the network card.
    • Disconnect the white and the black network wires by popping them up from the card with a spudger.
    • Remove the network card and set it aside.
    • The white wire is connected to the MAIN and the black wire is connected to AUX. This is important when reassembling your device.
  6. Dell XPS 15 9570 Display Replacement: adım 6, 3 resimden 1. Dell XPS 15 9570 Display Replacement: adım 6, 3 resimden 2. Dell XPS 15 9570 Display Replacement: adım 6, 3 resimden 3.
    • Unscrew the three screws from the screen bracket in the upper right corner using a Phillips #00 screwdriver.
    • Pry the latch up with a spudger or using the display for leverage.
    • Its easier to pull up on the latch if you use the display as leverage.
    Hi,
    I hope you can help me. Step 6, middle pic. Tucked in the corner, there is a black screw and a plate. That part broke off and I'm looking for a replacement. I don't think it's part of the display hinge but can't find it anywhere. Do you sell it?
    Thank you.
    All - Yanıt
    Hello, I am not ifixit. I made this guide for a school project.
    Nissan Uddin -
  7. Dell XPS 15 9570 Display Replacement: adım 7, 3 resimden 1. Dell XPS 15 9570 Display Replacement: adım 7, 3 resimden 2. Dell XPS 15 9570 Display Replacement: adım 7, 3 resimden 3.
    • Unscrew the three screws from the screen bracket in the upper left corner using a Phillips #00 screwdriver.
    • Pry the hinge upwards with a spudger or using the display for leverage.
    • Once the latches are 90° to the motherboard, the display is fully disconnected from the body of the laptop.
  8. Dell XPS 15 9570 Display Replacement: adım 8, 1 resimden 1.
    • Pull the display assembly away from the rest of the case.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I have a 9570 with a 1080 non-touch screen. This page lists an amazon screen that is 4k with touch. Looking at the product page, it does not mention the 9570 but does mention the 9560. Will the 4k touch screen work? I would like to make this upgrade but am skeptical.
https://www.amazon.com/NBPCLCD-3840x2160...
Brandon Budnicki - Yanıt
Thank you! Well done steps, concise and precise.
rblinzler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 25
Son 30 gün: 84
Her zaman: 8,869
