Ana içeriğe geç
Dell XPS 15 9570 Fan Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9570 Fan Replacement, Base Cover: adım 1, 1 resimden 1.
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Fan Replacement: adım 2, 3 resimden 1. Dell XPS 15 9570 Fan Replacement: adım 2, 3 resimden 2. Dell XPS 15 9570 Fan Replacement: adım 2, 3 resimden 3.
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Fan Replacement: adım 3, 2 resimden 1. Dell XPS 15 9570 Fan Replacement: adım 3, 2 resimden 2.
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Fan Replacement: adım 4, 1 resimden 1.
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Fan Replacement, Battery: adım 5, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Fan Replacement: adım 6, 1 resimden 1.
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Fan Replacement: adım 7, 1 resimden 1.
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Fan Replacement, Fan: adım 8, 2 resimden 1. Dell XPS 15 9570 Fan Replacement, Fan: adım 8, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  9. Dell XPS 15 9570 Fan Replacement: adım 9, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  10. Dell XPS 15 9570 Fan Replacement: adım 10, 2 resimden 1. Dell XPS 15 9570 Fan Replacement: adım 10, 2 resimden 2.
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  11. Dell XPS 15 9570 Fan Replacement: adım 11, 1 resimden 1.
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
Sonuç
Clay Caldwell
357 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 42
Son 30 gün: 136
Her zaman: 5,335
