Ana içeriğe geç
Dell XPS 15 9570 Speaker Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9570 Speaker Replacement, Base Cover: adım 1, 1 resimden 1.
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Speaker Replacement: adım 2, 3 resimden 1. Dell XPS 15 9570 Speaker Replacement: adım 2, 3 resimden 2. Dell XPS 15 9570 Speaker Replacement: adım 2, 3 resimden 3.
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Speaker Replacement: adım 3, 2 resimden 1. Dell XPS 15 9570 Speaker Replacement: adım 3, 2 resimden 2.
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Speaker Replacement: adım 4, 1 resimden 1.
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Speaker Replacement, Battery: adım 5, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Speaker Replacement: adım 6, 1 resimden 1.
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Speaker Replacement: adım 7, 1 resimden 1.
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Speaker Replacement, Speaker: adım 8, 2 resimden 1. Dell XPS 15 9570 Speaker Replacement, Speaker: adım 8, 2 resimden 2.
    • Remove the speakers from the back of the computer.
    • Replace speakers with Dell 6GTPY 91 Wh Battery.
Sonuç
Amount of screws holding battery in place may vary.
Bir başkası bu kılavuzu tamamladı.
Margaret Combs
525 İtibar
4 adet Kılavuz yazıldı
1 Guide Comment
Thank you for the tutorial!
Just did the swap with speakers form a DELL XPS 15 from an unknown model (most likely wasn't a 9570). Note that these speakers are common inbetween different XPS 15 models (at least XPS 9550 9560 M5510 9350 5520 5510 and Precision 5510 5520 5530 5540 PK23000RP00 TX47W 0TX47W) ******and can be interchanged.
The ones I just used were salvaged from an out-of-service XPS 15 but the parts can be sourced online easily (ex: https://www.amazon.com/Deal4GO-Speaker-R... )
Cheers
Antalog - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 50
Her zaman: 2,441
