Ana içeriğe geç
Dell XPS 15 9570 Wireless Card Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: adım 1, 1 resimden 1.
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: adım 2, 3 resimden 1. Dell XPS 15 9570 Wireless Card Replacement: adım 2, 3 resimden 2. Dell XPS 15 9570 Wireless Card Replacement: adım 2, 3 resimden 3.
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: adım 3, 2 resimden 1. Dell XPS 15 9570 Wireless Card Replacement: adım 3, 2 resimden 2.
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: adım 4, 1 resimden 1.
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: adım 5, 2 resimden 1. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: adım 5, 2 resimden 2.
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: adım 6, 1 resimden 1.
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: adım 7, 2 resimden 1. Dell XPS 15 9570 Wireless Card Replacement: adım 7, 2 resimden 2.
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: adım 8, 1 resimden 1.
    • Carefully remove the wireless card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Margaret Combs
525 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 64
Her zaman: 2,745
