Ana içeriğe geç
Dell XPS 15 L521X Hard Drive Replacement
Neye ihtiyacın var
  1. Dell XPS 15 L521X Hard Drive  Replacement, Back Panel: adım 1, 1 resimden 1.
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X Hard Drive  Replacement: adım 2, 1 resimden 1.
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X Hard Drive  Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Find and remove the four .4cm phillips head screws holding the hard drive in place.
  4. Dell XPS 15 L521X Hard Drive  Replacement: adım 4, 1 resimden 1.
    • Gently unplug and remove the hard drive
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
SHELDON SANTOS
614 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G7, Covino Spring 2018 UMass Dartmouth, Team S4-G7, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G7
3 Üyeler
1Rehber Yorum
This was a helpful tutorial, except for two small points. #1 - The yellow & red dots on step 1 are reversed; the T5 screws are the six along the two edges of the back panel and the P0 (Phillips #0) screws are under the face plate. #2 - the battery cable should ALWAYS be unplugged for component safety prior to doing any work on a laptop. An additional safety step (though optional) would be to physically remove the battery from the laptop prior to doing any work on it.
ICU Alex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 1,214
