Ana içeriğe geç
Dell XPS 15 L521X SSD Replacement
Neye ihtiyacın var
  1. Dell XPS 15 L521X SSD Replacement, Back Panel: adım 1, 1 resimden 1.
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X SSD Replacement: adım 2, 1 resimden 1.
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X SSD Replacement, SSD: adım 3, 1 resimden 1.
    • Find the single .3cm phillips head screw holding the SSD in place.
    • Remove the screw holding the SSD in place.
  4. Dell XPS 15 L521X SSD Replacement: adım 4, 1 resimden 1.
    • Gently pull the SSD out and replace.
Sonuç
SHELDON SANTOS
614 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G7, Covino Spring 2018 UMass Dartmouth, Team S4-G7, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G7
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 1,225
