Ana içeriğe geç
Dell XPS 15-L502X Front Cover Replacement
Neye ihtiyacın var
  1. Dell XPS 15-L502X Front Cover Replacement, Front Cover: adım 1, 1 resimden 1.
    • Before prying up on the cover, you may have to first remove a screw located inside the battery compartment (M2X3) and release the two latches. If you don't release the latches, you may snap the cover.
    • Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
    • Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
    • Cracking sounds are normal. Be careful and take your time removing this panel.
  2. Dell XPS 15-L502X Front Cover Replacement: adım 2, 1 resimden 1.
    • Work your fingers underneath the cover. Then, delicately pull the cover off of the computer.
    • The mouse pad is connected to the rest of the computer via two cables underneath the cover. These cables must be unhooked before the cover can be completely removed.
  3. Dell XPS 15-L502X Front Cover Replacement: adım 3, 2 resimden 1. Dell XPS 15-L502X Front Cover Replacement: adım 3, 2 resimden 2.
    • Unhook the cables connected to the mouse pad by flipping up the black tabs that hold either cable in place.
    • Releasing these cables can be done by hand or by using a spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Compton
398 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Baechle Fall 2015 IUPUI, Team 2-3, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S2G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 2,729
