Ana içeriğe geç
Dell XPS 17 9710 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 17 9710 Battery Replacement, Back Panel: adım 1, 2 resimden 1. Dell XPS 17 9710 Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove eight 5 mm screws from the back panel using a T5 Torx screwdriver.
    • Use the opening tool to loosen the panel on all sides and then lift it from the device.
  2. Dell XPS 17 9710 Battery Replacement, Battery: adım 2, 2 resimden 1. Dell XPS 17 9710 Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Remove seven 3 mm screws securing the battery using a JIS #1 screwdriver.
  3. Dell XPS 17 9710 Battery Replacement: adım 3, 2 resimden 1. Dell XPS 17 9710 Battery Replacement: adım 3, 2 resimden 2.
    • Use the spudger to detach the battery connector from the motherboard.
    • Gently unplug this attachment.
    • Remove the battery from the laptop.
Sonuç
Matthew McKeown
259 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Mellen Spring 2022 UMass Dartmouth, Team 1-2, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S1G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 97
Her zaman: 3,100
