Giriş
Replace the Display for Dell XPS 17 L702X. This guide includes instructions for removing the WWAN and WLAN cards.
Neye ihtiyacın var
Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
Close the display, and flip the laptop over so that the bottom faces upwards.
Remove the two 16 mm screws with a Phillips screwdriver.
Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
4 farklı kişi bu kılavuzu tamamladı.
4 Yorum
I have a question, my dell xps 17 l702x is having display issues. I've had it for about 6 years now and was using the original battery for that whole time, ( I know that's a long battery life), but my battery died and replaced it (battery plus bulbs) and now the display goes in and out and looks like it crashes then within 20 seconds, it comes back. Wondering what's going on. Any help is appreciated
Does it “flicker”/”spazz out” really weirdly when only on battery power? Try going into the Intel control panel and disabling the “Intel Power Saving Technology”
dell xps 17 l702x sir could you please tell me the best place to buy replacement screen?
dell xps 17 l702x please tell me the screen product number, would you guys fix it if I send it over? Do you guys have any branches in Delhi India?
