Ana içeriğe geç
Dell XPS 17 L702X Hard Drive Replacement
Neye ihtiyacın var
  1. Dell XPS 17 L702X Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Hard Drive Replacement: adım 2, 2 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Hard Drive Replacement: adım 3, 2 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 3, 2 resimden 2.
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Hard Drive Replacement: adım 5, 3 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 5, 3 resimden 2. Dell XPS 17 L702X Hard Drive Replacement: adım 5, 3 resimden 3.
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Hard Drive Replacement: adım 6, 2 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Hard Drive Replacement: adım 7, 3 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 7, 3 resimden 2. Dell XPS 17 L702X Hard Drive Replacement: adım 7, 3 resimden 3.
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Hard Drive Replacement: adım 8, 1 resimden 1.
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Hard Drive Replacement: adım 9, 2 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 9, 2 resimden 2.
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Hard Drive Replacement: adım 10, 3 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 10, 3 resimden 2. Dell XPS 17 L702X Hard Drive Replacement: adım 10, 3 resimden 3.
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Hard Drive Replacement: adım 11, 2 resimden 1. Dell XPS 17 L702X Hard Drive Replacement: adım 11, 2 resimden 2.
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Hard Drive Replacement: adım 12, 1 resimden 1.
    • Remove the hard drive casing.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Shin Sul
544 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-6, Bruce Fall 2015 CSU Fullerton, Team 2-6, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G6
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 4,341
