Ana içeriğe geç
  1. Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Slide the tab below the battery to the left and hold the tab in place. Slide the tab below the battery to the left and hold the tab in place.
    • Slide the tab below the battery to the left and hold the tab in place.
  3. While holding the tab, lift the battery out of its compartment. Release the tab after removing the battery.
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Loosen the module cover screw with a Phillips screwdriver.
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards. Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards. Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Remove the four 4mm Phillips screws fastening the first hard drive. Remove the four 4mm Phillips screws fastening the first hard drive.
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it. Lift the hard drive up to remove it from the case. Lift the hard drive up to remove it from the case.
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Remove the four 4mm Phillips screws on the second hard drive.
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Slide the hard drive towards the edge nearest you to disconnect it. Slide the hard drive towards the edge nearest you to disconnect it.
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Using the tab that says "THIS SIDE UP,"  pull away from the laptop to remove the hard drive. Using the tab that says "THIS SIDE UP,"  pull away from the laptop to remove the hard drive. Using the tab that says "THIS SIDE UP,"  pull away from the laptop to remove the hard drive.
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Repeat this step  for each hard drive. Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Remove the hard drive casing.
    • Remove the hard drive casing.
  13. Unscrew the screw holding the optical drive with a Phillips screwdriver.
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Using a plastic opening tool, pull out the optical drive. Using a plastic opening tool, pull out the optical drive. Using a plastic opening tool, pull out the optical drive.
    • Using a plastic opening tool, pull out the optical drive.
  15. Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Push and hold the tab inside the optical drive's opening with your index finger. Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces. Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Slide the spudger around the palm rest to release the clips. You may hear a crackling noise; this is normal.
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires. The mouse pad wires are still connected to the palm rest panel.
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Put the spudger below the black tab of the wider cable and push up to release. Gently pull out the cable. Gently pull out the cable.
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Insert the spudger below the black tab of the remaining cable and push up to release. Gently pull out the cable. Gently pull out the cable.
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Remove the palm rest from the laptop.
    • Remove the palm rest from the laptop.
  23. Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop. DO NOT lift the keyboard all the way up as there are wires that are still connected. DO NOT lift the keyboard all the way up as there are wires that are still connected.
    • Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
    • DO NOT lift the keyboard all the way up as there are wires that are still connected.
  24. Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open. Gently pull out the cable. Gently pull out the cable.
    • Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open.
  25. Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open. Gently pull out the cable. Gently pull out the cable.
    • Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open.
  26. Remove the keyboard from the laptop.
    • Remove the keyboard from the laptop.
  27. Close the display, and flip the laptop over so that the bottom faces upwards. Remove the two 16 mm screws with a Phillips screwdriver.
    • Close the display, and flip the laptop over so that the bottom faces upwards.
    • Remove the two 16 mm screws with a Phillips screwdriver.
  28. Gently flip over the laptop and open the back cover assembly.
    • Gently flip over the laptop and open the back cover assembly.
  29. Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach. Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach. Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
    • Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
  30. Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw. Gently pull out the WLAN card. Gently pull out the WLAN card.
    • Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw.
    • Gently pull out the WLAN card.
  31. Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach. Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach. Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach.
    • Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach.
    • Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach.
  32. Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver.  The card will lift itself. Gently pull out the WWAN card. Gently pull out the WWAN card.
    • Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver. The card will lift itself.
    • Gently pull out the WWAN card.
  33. Gently remove the wires for the WLAN and WWAN cards from their housing. Gently remove the wires for the WLAN and WWAN cards from their housing. Gently remove the wires for the WLAN and WWAN cards from their housing.
    • Gently remove the wires for the WLAN and WWAN cards from their housing.
  34. Unscrew four the 8mm screws directly under the keyboard with a Phillips screwdriver.
    • Unscrew four the 8mm screws directly under the keyboard with a Phillips screwdriver.
  35. Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver. DO NOT ATTEMPT TO REMOVE THE SCREW FROM THE WIRE. The screw is permanently fixed onto the wire.
    • Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver.
    • DO NOT ATTEMPT TO REMOVE THE SCREW FROM THE WIRE. The screw is permanently fixed onto the wire.
  36. Using the plastic opening tool, detach the connection from the cable to the board. Using the plastic opening tool, detach the connection from the cable to the board.
    • Using the plastic opening tool, detach the connection from the cable to the board.
  37. Gently remove the monitor cable from its holdings from the board.
    • Gently remove the monitor cable from its holdings from the board.
  38. Hold the plastic edge of the display firmly and lift to remove the display. Hold the plastic edge of the display firmly and lift to remove the display. Hold the plastic edge of the display firmly and lift to remove the display.
    • Hold the plastic edge of the display firmly and lift to remove the display.
  39. Unscrew the ten 8mm screws from the grey inner casing with a Phillips screwdriver.
    • Unscrew the ten 8mm screws from the grey inner casing with a Phillips screwdriver.
  40. Locate the sound card cable. Gently unplug the sound card cable. Gently unplug the sound card cable.
    • Locate the sound card cable.
    • Gently unplug the sound card cable.
  41. Find the orange cable with the letters MB. Gently insert the spudger below the edge of the black tab and pry it open. DO NOT attempt to pull out the cable on this step.
    • Find the orange cable with the letters MB.
    • Gently insert the spudger below the edge of the black tab and pry it open.
    • DO NOT attempt to pull out the cable on this step.
  42. Locate the wire on the side of WWAN slot. Using the spudger, gently pull out the cable. Using the spudger, gently pull out the cable.
    • Locate the wire on the side of WWAN slot.
    • Using the spudger, gently pull out the cable.
  43. Gently flip the laptop with its bottom facing you. Remove the four 8mm screws with a Phillips screwdriver.
    • Gently flip the laptop with its bottom facing you.
    • Remove the four 8mm screws with a Phillips screwdriver.
    • Remove the two 16mm battery casing screws with a Phillips screwdriver.
    • Remove the two 16mm corner screws with a Phillips screwdriver.
    • Remove the two 4mm screws inside battery housing with a Phillips screwdriver.
    • Removing the RAM is optional. This guide does not cover the removal of the RAM card.
  44. Holding the opening from the optical drive in one hand with the other hand holding the opposite side of the laptop, lift and remove the back cover assembly. Holding the opening from the optical drive in one hand with the other hand holding the opposite side of the laptop, lift and remove the back cover assembly.
    • Holding the opening from the optical drive in one hand with the other hand holding the opposite side of the laptop, lift and remove the back cover assembly.
  45. Unscrew the seven 4mm screws with a Phillips screwdriver.
    • Unscrew the seven 4mm screws with a Phillips screwdriver.
  46. Unscrew the 6mm screw on the DC cable assembly with a Phillips screwdriver. Lift the DC cable assembly out of the casing. Gently unplug the DC cable.
    • Unscrew the 6mm screw on the DC cable assembly with a Phillips screwdriver.
    • Lift the DC cable assembly out of the casing.
    • Gently unplug the DC cable.
  47. Lift and remove the Wi-Fi circuit board.
    • Lift and remove the Wi-Fi circuit board.
  48. Gently use a spudger to pry off the fan power cable. Lift and remove the fan. Lift and remove the fan.
    • Gently use a spudger to pry off the fan power cable.
    • Lift and remove the fan.
  49. Lift and remove the USB circuit board out of its housing. Remove the orange cable from the motherboard by gently pulling away from the connection point. Remove the orange cable from the motherboard by gently pulling away from the connection point.
    • Lift and remove the USB circuit board out of its housing.
    • Remove the orange cable from the motherboard by gently pulling away from the connection point.
  50. Loosen the six screws with a Phillips screwdriver. The screws are attached to the heat sink piece.  Do not attempt to remove them from the heat sink assembly.
    • Loosen the six screws with a Phillips screwdriver.
    • The screws are attached to the heat sink piece. Do not attempt to remove them from the heat sink assembly.
  51. Gently lift and remove the motherboard. Clean the thermal paste with rubbing alcohol and a microfiber cloth or non-abrasive tissue. Clean the thermal paste with rubbing alcohol and a microfiber cloth or non-abrasive tissue.
    • Gently lift and remove the motherboard.
    • Clean the thermal paste with rubbing alcohol and a microfiber cloth or non-abrasive tissue.
  52. Unscrew four 4mm flathead screws with a Phillips screwdriver
    • Unscrew four 4mm flathead screws with a Phillips screwdriver
  53. Gently lift and remove the right side speaker piece out of its casing. Gently lift and remove the right side speaker piece out of its casing.
    • Gently lift and remove the right side speaker piece out of its casing.
  54. Carefully remove the wires from the holdings.
    • Carefully remove the wires from the holdings.
  55. Gently lift and remove the left side speaker from its housing.
    • Gently lift and remove the left side speaker from its housing.
  56. Carefully remove the wires from the holdings. Remove the speakers with the cables still attached. Remove the speakers with the cables still attached.
    • Remove the speakers with the cables still attached.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eddie
394 İtibar
2 adet Kılavuz yazıldı
Takım
CSU Fullerton, Team 2-6, Bruce Fall 2015 CSU Fullerton, Team 2-6, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G6
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
You do not need to go further than step 47 to get to the speakers. That way you avoid messing with main board, and thermal paste and stuff. You can even do it without removing wifi board with some finesse.
Oleg Lego - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,754
