Neye ihtiyacın var
Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
Close the display, and flip the laptop over so that the bottom faces upwards.
Remove the two 16 mm screws with a Phillips screwdriver.
Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
Unscrew the ten 8mm screws from the grey inner casing with a Phillips screwdriver.
Gently flip the laptop with its bottom facing you.
Remove the four 8mm screws with a Phillips screwdriver.
Remove the two 16mm battery casing screws with a Phillips screwdriver.
Remove the two 16mm corner screws with a Phillips screwdriver.
Remove the two 4mm screws inside battery housing with a Phillips screwdriver.
Holding the opening from the optical drive in one hand with the other hand holding the opposite side of the laptop, lift and remove the back cover assembly.
Make sure you remember to remove the SD card cover before pulling off the back cover
3 farklı kişi bu kılavuzu tamamladı.
